Old 04-09-2021, 11:27 AM
ERA 626's Avatar
ERA 626 ERA 626 is offline
Cobra Make, Engine: CSX 6079 482CI CSX cross ram
Originally Posted by jhv48 View Post
If you want to bleed the new cylinder the easy way, install it, attach the hose, open the bleeder valve and fill up the reservoir. Gravity will do the bleeding for you. Just make sure you don’t run the reservoir dry. And, yes, it really does work.
agreed I have done it, several times... also you can get a plastic bleeder bottle with a plastic hose that runs into the bottom of the bottle. Make sure you fill the bottle with fluid so that the hose is in the fluid. Then attach the other end of the hose to the bleeder, loosen the bleeder. Push the pedal in and out several times. DONE.
