grybrd123 Is there any chance you could take a shot of the rear spring tower from the bottom side? I am scratch building and my rear spring tower is constructed a little different than yours shown here . Not saying mine is right because I have found many mistakes in my plans. Where mine looks different is on the side view mine has 2 small holes at the bottom of the side plate. Yours has one. Also mine has a weld across the side plate at the top. This is where the side and top plate meet. The side plate also wraps around about 135*to the inside and is also welded into the 2 spuds that the bolts go thru to hold the rear end in. I have seen other make this part the same way yours is made. This makes me wonder what way is correct? Were original Cobras made both ways? If you need a picture I can snap one to make it more clear what I am asking about.
Thanks Mark
