Originally Posted by EM-0785
You mentioned you want single adjustment coilovers. If so, the QA1 part number scheme has the same numeric portion but with the letters DS in front for single-adjustable (DD for double-adjustable).
QA1 tech support can also walk you through the decision point considerations to verify in your application if helpful (measuring, end types, spring length, axle weight, etc.). Best of luck. Brent
THANK YOU VERY MUCH FOR THE ADVICE Brent !!!
I've placed my order 2 days ago with Double adjustment QA1.
