If you're really looking to lower your boiling point as well, do not run water in your cooling system! There is a new product out there called "Evans Waterless Coolant". Jay Leno showed the product on his site, and a friend of mine is running it on his Nomad with his LS3 engine. It's non corrosive, and you will never need to change your coolant ever again. There is a flush product if you have run water and Anti-Freeze, and then after you have ensured all the water is out of your block & radiator, simply add the Evans Waterless Coolant. You can google the product. Good luck!
