Old 05-06-2021, 08:45 PM
twobjshelbys's Avatar
twobjshelbys twobjshelbys is offline
Originally Posted by NRP/MN View Post
This picture is an AFCO master cylinder designed for a remote reservoir. I don't believe this this is available any longer. there are similar but not exact available. Throughout my entire career I have had the best luck with the 74 series Tilton masters, less wheel drag and long life. The AFCO's and Wilwood were patterned after these. Typical is a 7/8" front and 1" rear bore. You can run identical bores on both front and rear but occasionally have a brake balance issue that you cannot adjust with the balance bar on the pedal.
My source for the part above was the guy that did the Cobras at HST. He said that the AFCO parts were discontinued and the CNC parts were qualified in their place.
I ordered mine directly from CNC (and a rebuild kit, while I was at it).
Clutch - P/N 712-3/4
brakes P/N 712-5/8 & P/N 712-7/8
Edit: I didn't see the previous reply as this one sat in an edit window while I did some other things. Oh well... I don't know what there might be equivalent parts.
Tony
CSX4005LA
