Holley Fuel Pump 12-125
Well, my original fuel pump (SW 82052) died about 1/2 mile from the house. Able to get home by pouring fuel down the fuel bowl vents a few times. The old pump is not available from SW. Their replacement pump, SW 82091, does 43 GPH and 8 PSI.
Several years ago, expecting this event, I purchased a Holley 12-125 pump, 125 GPH and 7 PSI. Its supposedly quiet since it is a geo-rotor pump.
Here's my question, switch pump would be better? Or perhaps another pump?? The Holley pump is heavy and will have to be mounted (with nut inserts) to the frame behind the left rear wheel. Not particular easy given the 6 inches available to drill, etc. If I purchased the new SW pump, it looks lighter like the original and could be mounted to a vertical fiberglass truck panel like the old.
The car is ERA454, 425 HP, 650 DP carb. Thoughts please.
