Old 05-20-2021, 06:51 PM
jknich's Avatar
jknich jknich is offline
Did you buy the anti clockwise speedometer? If so you need a reverser angle drive mounted to the back of the speedometer. On my set the temp gauge requires a 100-300 F sender and the fuel gauge takes a VDO type sender. Mechanical tach. I think I'll use the can and face plate on my electric tach. I thought about getting a Tbird Yblock tach drive distributor and using the 289 drive gear. The speedometer and tach use 18mm x 1.5 nut. You can get them from speedometer shops online. Common motorcycle size.
Jim Nichols
