Old 05-23-2021, 01:51 PM
sunman's Avatar
sunman sunman is offline
Change out the #4 like you think. It sounds like your 12 volts is dropping to low to run EFI when second fan kicks in. Just a guess but your wire is to long/to small for sure with that amp draw on the charging circuit. Or just a suggestion I think a shortened alt wire should go down to the starter terminal that is on the disconnect side of cut off switch just for safety. Shorter wire might fix prob without going bigger
Chaney Shores Studio
