Old 05-23-2021, 03:14 PM
twobjshelbys's Avatar
twobjshelbys twobjshelbys is offline
Originally Posted by sunman View Post
Change out the #4 like you think. It sounds like your 12 volts is dropping to low to run EFI when second fan kicks in. Just a guess but your wire is to long/to small for sure with that amp draw on the charging circuit. Or just a suggestion I think a shortened alt wire should go down to the starter terminal that is on the disconnect side of cut off switch just for safety. Shorter wire might fix prob without going bigger
And if low voltage after the fan is the problem then it's more likely the alternator capacity than wire size/IR drop.
Tony
CSX4005LA
