Old 05-31-2021, 09:49 AM
sunman's Avatar
sunman sunman is offline
The 1/0 positive post alt wire is hot all the time and should be fused if it goes to back of car. You can’t use starter terminal it’s connected to car power on switched side of disconnect. The white exciter wire power circuit would be switched with second points in dual switch. I’m thinking you have a CS130D by the 4 pin plug. My 12SI alt was a true one wire only
Chaney Shores Studio
