Old 06-03-2021, 09:33 PM
kitcarbp's Avatar
kitcarbp kitcarbp is offline
Cobra Make, Engine: West Coast, 460 Ford Racing Crate w/ TREMEC TKO 600
Ok. So if your contemporary cobra is still using the manual Jag rack, it appears you set the preload using shims on pinion. Other threads here on Club Cobra discuss it. Here is a link to the rebuild process where the shims are used to set the preload.
Manual Rack Rebuild
"...some assembly required, ages 8 and up...... well that took longer than expected......
