Old 06-15-2021, 08:17 AM
aa909's Avatar
aa909 aa909 is offline
Before you install a heat shield, run a voltage drop test when she's hot on both the positive feed to the starter and the ground to the starter. Dicey cables/solenoids are more common than really bad heat soak. And the drop test only takes 30 seconds per side.
my little hydraulic lift only goes up enough for me to squeeze under the car with very little clearance. If I go under there to test the starter cables before the oil pan cools I'm coming out with some serious burns but if I wait for it to cool then the issue self resolves
Any other test I can perform when the car is cool?
Thanks
Art
