You just need the bolt out of the ride tech part no bolt on piece
4 Speedway kits will do it
The bottom of shock needs to be closer to bracket
You can see in photos bottom spacer looks thinner
That fixes the shock to mount bolt angle
The Speedway mounts are a full 5/8 inch bolt
Normal ride height looks good at 13 1/2” with 26” tires
With 12” springs the car rides to high and adjuster nut is at bottom of shock
10” srings at 200 lb give a softer ride that can be stiffened with shock valve adjuster
Springs are easy to change if needed
Chaney Shores Studio
