A better description of the symptoms would help. For example, when the fuel level gets to 1/4 tank, is the problem there even on a cold start, or does it have to be run for a while before the symptom appears? Is the problem there only on startup or does it occur while the engine is running? And is your fuel pump lower than the bottom of your tank?
Tommy
Previously owned EM Cobra
