If you don't have a jambnut then probably it was installed with Loctite.
You can heat the shifter lever shaft with a heat gun just below the Knob and it will liquify the Loctite.
Or
Lift the boot up and remove the the two bolts attaching the shifter lever to the shifter then pull the boot off.
Or
Wrap the knob with two layers of duct or masking tape. Install a screw type hose clamp around the largest circumference area of the knob. Then you can use Channel-locks to remove the knob without marring the finish.
