Old 06-27-2021, 03:32 PM
patrickt patrickt is online now
Originally Posted by aa909 View Post
... but if it begins to exhibit the same slow crank after it gets hot (like the original) then I assume it's clearly a heat soak issue and the solenoid is wearing over multiple heat cycles?
Either that or the screws are backing out again. I don't think you have a heat soak issue. A motor is never tighter than the day you bought it.
