Originally Posted by eschaider
A couple of thoughts,
Torque vs Horsepower
Torque not horsepower is what breaks transmissions (and rear ends). If I have 800 hp but it comes at 10,000 rpm that only requires 420 ft/bs of torque. If I have another 800 HP engine but it comes at 3000 rpm that requires 1400 ft/lbs of torque. Guess which one is most demanding on the drive train?
Ed
Not quite accurate. You have to figure in the transmission and differential ratios in the torque that's delivered to the axles.
Torque to the axle= engine torque x transmission ratio x differential ratio.
