Originally Posted by patrickt
They're nice pieces and the folks on my other forums like them a lot. I run an original DIF iron block from centuries ago, so it's well seasoned to say the least. But if I didn't have that I would consider a BBM.
Now, I will say I like the following:
I thought that was quite good also Patrick.
For the uninitiated, BBM stands for
Bear Block Motors. Bear Block Motors is located SoCal and produces a wide range of block, head and intake manifold products for FE engines. They also have a 392 Hemi block offering and a to die for Coyote block.
This is a link to their website click here =>
Bear Block Motors. They produce some extremely high quality iron and aluminum castings using casting talent and engineering talent from Hyundai, if I am not mistaken. The parts are on par with the best OEM manufactured cast components you can find anywhere, these are not your typical aftermarket alternatives.
Ed
