Originally Posted by FredG
You might want to consider replacing any rubber connections from the fill tube.[/url]
You definitely want to change the rubber connections! The fuel ate through mine and started leaking in a parking garage. Luckily the level wasn't too far past the bottom of the inlet, but messy none the less. I don't think "filler neck hoses" are intended to be in permanent contact with gasoline.
