Originally Posted by Gaz64
Hello Jim,
Can you clarify what emulsion tube you have, like F7 as example?
120 is not a Weber IDA emulsion tube number.
That could be your idle jet holder.
You could also solve your light throttle stumble by adding the IDA 3rd progression hole.
Gary
Gary,
I stand corrected, emulsion tube is F7, 120 is idle jet holder.
Thanks. I do not have the equipment nor the expertise to drill 3rd hole as I have reasearched that option, One really needs to be precise else you ruin a very expensive set of carbs.
Thanks,
Jim
