Glad to hear from you Artur!
You got a great car and all you are looking for is here
The front suspension recommended by Ed Double Venom and Don Scott is a complete Heidts unit with Wilwood brakes
You add a 2 1/2” extension to top of shock
You weld a small triangle to frame and go strut less
On the 8.8 rear I use easily modified Speedway shock mounts with ProShock coil overs
The rear I have developed is what CR II used but with better mounts and upgraded shocks with 5/8” spherical bearings and is bolt in
Springs are 170 lbs and might go down to 150 lbs to address the harsh ride the CRs have
The stock shock bolt holes are retained and reinforced with more steel
The triangulated 4 link is a roll bind b*t*h that Ford sorta fixed with soft bushings and massive understeer
Using Heim jointed adjustable upper control arms reduces the roll bind
Brakes from North Race Cars. Call Richard at 816-436-1610 check out the website
I will have pictures, part numbers, links and more details coming soon but...
I’m on vacation road trippin rite now!
Party On
Wyatt
![](http://www.clubcobra.com/forums/image.php?u=40245&type=sigpic&dateline=1707249881) Chaney Shores Studio
