  #39 (permalink)
Old 07-29-2021, 08:41 AM
Roylerumble Roylerumble is offline
Originally Posted by Sycraft View Post
does anyone have the measurement for the rear lower control arms, center to center hole? Looking at having heim joint lowers made to get rid of the spring perch when I do a coilover conversion. found some jeep ones These control arms are fabricated from 1.750" OD x 0.120" W DOM tubing in the USA. Both ends have massive 1.25" chrome moly heim joints with misalignment spacers to give a total adjustment range of 15.4"-17.5". or these pending I can get the adjustable measurement range..
https://www.bmrsuspension.com/?page=...694&superpro=0
https://steinjager.com/shop/Control-...Baron-J0047318
I was thinking a similar approach. I want to see if I can modify a set of fox body rear lowers that have the mounts for the rear sway bar. I have all my parts boxed until start my build, but will see if I can get into the shop to pull them down to get some measurements if no one beats me too it.
