  #22 (permalink)
Old 07-29-2021, 04:47 PM
nkb's Avatar
nkb nkb is offline
Cobra Make, Engine: Alloy Shelby CSX 8057/Kirkham 1010, 289 Vintage Lykins Build
Originally Posted by Buzz View Post
The devil is in the chassis details. ERA builds both (big and small block) models on a rectangular tube chassis with a coilover suspension. For the slab, SPF uses an authentic round tube chassis with the correct transverse leaf suspension. The body shape is beautifully executed and if superficial appearance is a primary driving factor, it certainly holds its own against the ERA. I suppose it would boil down to whether you feel the authenticity factor is worth the relatively reasonable bump in the sticker price.
And as a follow-on question, is there a difference between the SPF and CSX slab sides (body, frame, suspension) since I understand SPF (Hi Tech) supplies Shelby? I had initially thought the only difference was in branding and a CSX VIN number. But, perhaps there are more physical differences for the two slab sides even though ostensibly from the same manufacturer ?
