Old 08-04-2021, 09:14 AM
twobjshelbys's Avatar
twobjshelbys twobjshelbys is offline
Originally Posted by Ahshoe View Post
Try adjusting the idle mixture screws to see if this makes a difference.Also make sure they are set the same or very close to the same.
This is a fuel injected 8-stack from Roush. I had the same engine. It's quite finicky.
After it warms up does the idle stay at 1150?
Do you have the dual fuel pumps? Have you checked pressure? I added a pressure gauge at the end of one of the fuel rails.
Tony
CSX4005LA
