Old 08-06-2021, 04:13 PM
MOTORHEAD's Avatar
MOTORHEAD MOTORHEAD is offline
Cobra Make, Engine: KIRKHAM 427 S/C, SHELBY 427 ALUM. STROKER
No exh manifold leaks.
Balance good at idle, will ck at higher rpm.
Plugs all clean,almost too clean, but last run was only 10 mi.
Never had this problem with the single holley, got to be related to the weber set-up.
Let off on the gas pedal and it backfires, then push in the clutch and it instantly stops backfireing
"When Injustice becomes Law,
Rebellion becomes Duty." T. Jefferson
