Sorry if I wasn't clear. After 3 or 4 bleed presses (open bleed, press brake, close bleed, allow pedal to return to top), I'd top off the master cylinder. I was catching the purged fluid in an
oil bottle. I topped off the master in that manner probably 6 times passenger side and then 3 times driver's side and each time pushed fluid and air (I was using clear plastic tubing).
I guess I'll have to get the car up on jack stands again and stomp on the brakes to see if there's a leak as the master shouldn't have been down so low even after 2 years of not running...).
