  #48 (permalink)
Old 08-23-2021, 06:31 AM
Sycraft's Avatar
Sycraft Sycraft is offline
Cobra Make, Engine: ford 302
Originally Posted by MaSnaka View Post
I saw it like this...when I ditched the spring perch and installed the coil overs purchased thru CRII right before they closed I was provided with a spacer and long bolt to attach where the shocks originally attached to the chasis. That put 100% of the load on 1 bolt per side. Looked like failure waiting to happen. So I designed a bracket that i could install (not being a welder) that would beef up the shock mount. Double shear, not single shear. I also added adjustable upper and lower control arms to adjust the pinion and alignment. Pictures in my gallery.
John
Are you using a rear sway bar? if so. how is it attached. I want to do similar control arms, but thinking of only having 1 side adjustable and welding a tab for the sway mount
