Thread: Hard shifting
Old 08-26-2021, 02:34 PM
DanEC's Avatar
DanEC DanEC is offline
Originally Posted by cobragene View Post
I installed a McLeod pro street clutch and alum FW, I was certain I got the Lakewood bell dialed in correctly, but toploader with 5K mile rebuild is hard to get into any gear especially 4th at high speed and RPM. Before this the trans shifted good. Is there a way to pull trans but not bell and clutch to check it again?
What type shifter do you have in the car? It’s hard to be certain from your description but I would suspect the shifter needs to be adjusted so that the neutral gate is aligned correctly. If the transmission shifted cleanly before then it should still unless the shift linkage is misaligned. Just unbolting it and re-bolting it back to the transmission, even if care is taken to not change any of the rods, can cause subtle changes in the neutral gate alignment that will create shifting issues.
ERA 782 Running
