What clearance did you set for your disc to flywheel air gap when the clutch is released?
You should be using 0.020" to 0.025".If you set it up for less, the trans will be all but impossible to shift especially once the clutch heats up. More and you will begin to experience clutch slip depending on your pressure plate load and the disc friction material.
Ed
Reason: Spelling & Grammar
