Originally Posted by nkb
Another differentiator between the SPF and the ERA is the ability to control the painting process.
You do know that if you change your mind before ERA starts the actual build process Peter just gives you your check back.
I did the entire build process, from start to finish, on nothing more than a hand shake... and there was never even a single blip along the way. Even if you end up going with SPF, which I doubt you will, you should reserve your queue spot now with ERA.
