Thread: Blas
Old 08-29-2021, 07:35 PM
spf645's Avatar
spf645 spf645 is offline
Cobra Make, Engine: Superformance, 351w
Engine off, tried the lights, then the engine over ride to the cooling fans. Needle was steady in both test, and to to the left as you stated. Needle bounce would happen in maybe 10 second intervals the last time driven. From steady to fast 10 amp swing movement. 12 ga wire test you mention, I've not had time to try yet.
Keep the ideas coming. Thanks again Patrick
I'll take another look at the battery ground. But car starts great now with new battery, even when engine is hot. Thanks NROTOXIN
