Old 09-01-2021, 01:26 PM
DanEC's Avatar
DanEC DanEC is offline
I’ll let other comment on the oil issue. On the rings, the rings rotate constantly and randomly in operation due to the cylinder honing and maybe some other factors. So they will likely be in a different orientation every time you shut the motor down unless your cylinder walls are worn glass smooth and even then they may move around some.
ERA 782 Running
