Old 09-01-2021, 07:07 PM
Blas's Avatar
Blas Blas is offline
Cobra Make, Engine: SPF#0760
If you have electric fans, make sure it (they) are operational. If the fans are inside the engine compartment, be sure they are pulling air thru radiator. Fans should be shrouded to maximize their efficiency. Fans activated at a lower temperature also help. Is your front opening sealed all aground to trap captured air and direct it thru radiator. A manual fan switch is helpful too.
Some have had good results with the Evans coolant....
Blas
SPFWiringDiagrams@Comcast.net
