I picked up a set of Balkamp motor mounts (Anchor equivalent 2287) at the local NAPA store and what do you know, they have bolts installed through the rubber portion of the motor mount. Looks like one of the manufacturers has been working on a similar problem. I believe that these are intended for 302s even though I'm using them on a 351. The original 351 mounts wouldn't fit the piece that's welded onto the frame. Anyway, should help the torque-over problem without having to modify the mounts.
h dog
