Originally Posted by 1985 CCX
You will be fine, my rears are 5yrs now and I'll change most likely change next season.
I've driven as far as NJ, been around Indy, raced at Pittsburgh and daily driving alot.
I am a fan of the BB and never had a failure.
If your car is aligned right, they are fine. Plus I live in New England so roads are bad, the tries work with the car's suspension. Just simple alignment = no issues.
Congrats Doug!
I just had a 4 wheel alignment done on the car. I had them set it at 1/8 toe in, 1/2 degree negative camber, and 3 to 5 degrees positive caster. Hopefully thos eare good settings for the Billboards. I forget what we set the rear to. Great to hear from you Jeff. Thanks for the input.
