Old 09-30-2021, 11:55 AM
raybones raybones is offline
Cobra Make, Engine: Superformance MKIII Ford Big Block
Default solid lifter flat tappet engine oil?
For those of you with Flat Tappet Solid Lifter cams what oil are you using after breakin?
The Cobra I bought in the spring has a FTSL cam and I will be changing the oil. I understand that most modern oils do not have addiquite zink levels to prevent camshaft lobe wear when the cam is activating the valves through Flat Tappet Solid Lifters.
Thanks for you for your input.
Ray Sackett
