Initially I cringed at the return line prospect . I went with fitech . Moro so makes a nifty item . It’s about a 4 inch long piece of tubing with a return line fitting in it . You cut your filler tube and put this piece in and you’ve got your return line . I’ve put 2,000 miles on the fitech system . Started, ran perfectly . No issues . I bought a system with the force fuel unit . O2 is in tube #4 on the driver side .I’m not a rookie , been a mechanic , owner of a repair shop for twenty years . This was the best improvement I made to the car .and to add, my car is a 428 , aluminum heads , fully built , roller cam , rockers , all the usual build stuff , radical cam . The system has no problem running properly with a lumpy cam and high compression. My experience has been a good one .
