Originally Posted by Gaz64
Glen, I think you'll find you need to have a column mounted stalk with a cam operated cancelling mechanism.
Maybe there's a rule buried somewhere else. But that regulation is pretty clear:
100—Operation and visibility of direction indicator lights
(1) A direction indicator light fitted to a motor vehicle must—
(a) when operating, display regular flashes of light at a rate of not over
120 flashes a minute and—
(i) for a motor vehicle with 4 or more wheels—at least 60 flashes a
minute; and
(ii) for another motor vehicle—at least 45 flashes a minute; and
(b) be able to be operated by a person in the normal driving position; and
(c) be wired to an audible or visible device in the vehicle that tells the driver that the direction indicator light is operating; and
(d) flash at the same time and rate as any other direction indicator lights fitted on the same side of the vehicle
