Originally Posted by Gaz64
Bore size is irrelevant.
Uhhh, are you sure about that? Lift force (for blowing that head up through the ceiling) is found by multiplying the pressure times the area. That's why a hovercraft can get off the ground by using only 7 lbs. of pressure.
Of course, you should not just take my word for it. See:
https://www.discoverhover.org/infoin...ors/guide4.htm
