  #38 (permalink)
Old 10-14-2021, 12:07 PM
cycleguy55's Avatar
Originally Posted by Gaz64 View Post
Bore size is irrelevant. 100 psi from an air line into the cylinder will still be 100 psi.
Bore size matters. 100 PSI (Pounds per Square Inch) has a greater overall force when applied to a greater area. It would be 200 lbs force when applied to 2 square inches, but 500 lbs force when applied to 5 square inches.
That's also why a narrow bicycle tire (e.g. 700 x 25c) needs more pressure (100-125 PSI) to support a given rider weight than does a wider tire (e.g. 700 x 38c) - which might only need 60-80 PSI.
Brian
