Old 10-15-2021, 12:10 PM
Blackbart's Avatar
Blackbart Blackbart is offline
Cobra Make, Engine: ERA #804
Default ERA Brake Master Cylinder adjustment rods
I just changed out the non-functioning hydraulic brake light switch on the master cylinder on #804. The new switch solved the problem of no brake lights . This subject has been covered several times in this forum including a "factory" bulletin on how to replace the switch. While I was under the car I did an inspection of other components of the brake system that is covered by the aluminum box protecting the master cylinders. I found some play in the adjustment rods as shown in the video link below. Just want to verify that this is not something I should be concerned with. Thanks in advance.
Gary
https://www.youtube.com/watch?v=YzI7iJP7CR0
ERA #804 walk around
https://www.youtube.com/watch?v=NSt_uMDOurM
