Old 10-16-2021, 11:27 AM
Blackbart's Avatar
Blackbart Blackbart is offline
Cobra Make, Engine: ERA #804
Thank you Patrickt and Dan. She's all buttoned back up and everything is working fine. Patrickt, the brake bias was fine before I installed the new switch so I left that as is.
While the car was up in the air I installed a 180 degree oil cooler thermostat adapter in place of the standard cooler adapter. I wasn't getting sufficient oil temps with no thermostat and now I get consistent 180-200 degrees which is much better for the engine.
The Derale oil thermostat sandwich adapter is plug and play with the correct 3/8" NPT ports.
https://derale.com/product-footer/fi...iameter-detail
ERA #804 walk around
https://www.youtube.com/watch?v=NSt_uMDOurM
