Originally Posted by RonKahn
Yes, I have the same setup, without the horizontal shock mounts on the frame. I have not decided if I am going to put them on or not. I want to make sure I can get the widest tire under the car first. Is all you did is just mount to the existing mower mounting hole on the rear end and then drill a hole on the upper shock mount? I would like to get all the same items you have there. If you can post all the part numbers for the shocks and the mounts that would be great!
I have not done it yet, but upper mount will use 1 exiting hole and second hole will b e drilled, the lower mount bolts to the axle with 2 bolts too. I believe I posted what I have used so far. But once I actually do the work, I will post pics and specify what worked. I am hoping my QA1 rears are correct, as far as I can tell and measure, they should ride right in the middle of the travel for the shock.
