Old 06-22-2002, 04:52 AM
Mike I's Avatar
Mike I Mike I is offline
Cobra Make, Engine: E-M Cobra - RCR GT40
Exclamation
xlr8or,
I'm not disputing Bob's recommendation. By all means check the thermostat first, it's certainly the most likely cause and the simplest thing to fix. My first impression when I read that you installed the new heads and intake on your motor is that you may have installed late model parts from an LT-1 with the reverse flow cooling design. They would require the special reverse flow pump and drive system to work properly. Just a guess in case the thermo is not the problem. Good luck.
Mike
