Old 11-18-2021, 10:25 AM
hauss's Avatar
hauss hauss is offline
Cobra Make, Engine: 427 manowar forged crank roller rockers . BIG CAM.
what I was trying to get at was the fact that the carrier which holes the ring gear and the pinion which holds the pinion gear have shims so you can adjust the clearances for the gears. The bearings are pressed on so you will damage them when removing them to get to the shims. That"s why you need the dummy bearings so you can remove by hand while setting up your clearances. For me it was a process I rushed it the first time and had to learn the hard way take your time read the paint ! That"s the most important thing it will tell you whats going on with your gears.
