  #37 (permalink)
Old 11-18-2021, 08:42 PM
old willy's Avatar
old willy old willy is offline
Cobra Make, Engine: Mine, small block FORD
Hi Jim,
Thanks for that info, I will check them out. I did check out your photo gallery and are these the same headers under construction that you have pictures of? They look good, a tight fit to be sure but I think anything is going to be tight, no need to duct the heater into the foot boxes is there....
I also just read a new post about rear axle part numbers, I can't help out with if the information is correct or not but it is now a half shaft option I should consider, it will still need some machining to adapt the ends but no CV boots to contend with, no custom spline axles to source and much more period correct looking.....hmmm this place just fills your head with all kinds of ideas
Yes, I know,....... but it's mine you see.....
Perhaps he was always a shyster, but we just chose to over look it for awhile.
You build what you like and I will build what I like...it's all good
You know that guy,
The one in the neighborhood who likes to hang around the garage while you are working and talk about back when he had that killer 1977 Chevy Mustang
