Old 11-22-2021, 03:54 PM
Chicagowil's Avatar
Chicagowil Chicagowil is offline
I believe what you have for an 8.8 rear axle is the later setup with disc brakes and the sensor wheel (missing) for the ABS. The shorter axles may cause a problem with the mounts for the rear caliper. Do a trial fit of the rotors and calipers to see how everything aligns.
I will check out my front track tomorrow. What is the outside width of your front fenders (side to side) on your CRII. I have a very early CRI. I assume they are the same.
Thom
