The hub shown is for the front.
You can’t/ won’t use the reluctor ring that is pressed on axel shaft for 94 and up. ABS? On a Cobra?
The hub diameter/ rotor hole ID is bigger for the SN95 rotor and requires a ring spacer to use early axels with SN95 rotors. SN95 brackets do not work you need custom brackets
I’m using SN95 brakes with a rotor hole spacer and the North Race Cars one piece anti-moan brackets. It’s a complete kit with everything but the brake lever
Chaney Shores Studio
