Hi Rodney You didn't say what motor you have or how much cam is in it. TWM makes throttle body type webers up to 55mm. Check their web site. I have a fuel injection system in my car. I am going to a TWM when they build the 58mm bodys. If you have the money F.A.S.T or Speed Pro, same company, make a great brain for about 3k. I have 50 lb. injectors on my car and are going to 72 lbs when I turn the boost up past 10 lbs. My engine is 452 FE. 9.2 compression 501-533 comp cam, Shelby all alum. 328rwhp. 430 tork at the rear wheels. Ildes at 750 without the shake. It is the way of the future. My speed-pro is wide 02 sensor, sequential injection, fuel and timing pre cylinder. Hope this helps you Good Luck with your car. Rick Lake
