Old 12-02-2021, 07:36 PM
Earl J's Avatar
Earl J Earl J is offline
Cobra Make, Engine: GT350,289 w/48IDA Webers
Send a message via AIM to Earl J
Originally Posted by lumpy3339 View Post
Hello I am looking for source for a roller cam with profile suited to 289 with weber 48ida intake. I spoke to comp cams and they do not offer the inglese #31-491-8 any more. Any recommendations would be appreciated thanks jerry
Jerry,
I run this cam with my Weber set-up. It’s from Crane Cams Compucam Hi Roller series. It’s a billet cam. Part number 368021 Grind number R-234/3335-2-12
Duration @ .050 intake 234, exhaust 244, advertised duration IN 298 EX 308, Valve lift 534 for both. It’s for 1962-up Ford Mercury 221- 302. It’s fairly hot but very streetable. This is a solid roller cam. If you work out the numbers the lobe separation works out to 112 degrees (if that is important to you). I also run a custom Roush roller mechanical fuel pump encentric. Here is a pic of the cam card and my set-up. (I find posting pics a bit challenging and struggling, I have a message into the admin for assistance)
~Earl J
Earl J Castillo
VP NorCal Region SAAC 2012
